G
Guest
Guest
System specs:
*Win 98se
*Asus A7v133
*AMD 1.2Ghz C
*2 Maxtor HDs configure for Raid 0
*Radeon graphis card
*Sound Blaster Live
*2 netgear NICs
*Asus CD-s360 CDROM
*Yamaha 401t CDRW
The system shows both CD drives in bios and during bootup. Both drives will spin for a few seconds during startup. If I start with a disk in the drive, it will spin, then stop and the light goes off. When I get to windows everything looks great. No conflicts with any IRQs. No conflicts under device manager. The drives show up properly under device manager. The drive letters show up in explorer and I can right-click and eject the disk from explorer. When I insert a disk, the disk doesn't show up. If i click on the drive letter in explorer (with a disk in), I get "E:\ is not accesable, the device is not ready." This problem existed before installing windows. Sometimes if I switch the cables around, reset the jump accordingly, the system will read from the CDROM. Then as soon as I change the disk, the system stops reading from it. I tried a variety of ribbons and combinations of Primary, Secondary, master, slave setups, with the appropriate jumper settings on the CD drive. Nothing's working. I would greatly appreciate any help on this.
*Win 98se
*Asus A7v133
*AMD 1.2Ghz C
*Sound Blaster Live
*2 netgear NICs
*Asus CD-s360 CDROM
*Yamaha 401t CDRW
