To start things off, this is my current build. I know some of the parts are not an ideal brand but I've never had problems with any of these companies in the past when upgrading my other computers. And... I had a limit of roughly $1000 (after shipping) to build this rig.
Mobo - Asus P8P67 LE B3 Rev 3.0
CPU - i5-2500k
GPU - Zotac GeForce GTX 560 ti
RAM - 2x4GB Corsair Vengeance DDR3 1600Mhz
PSU - Ultra LSP 750W
OS - Windows 7 Home Premi OEM
All drivers are up to date
No Overclocking done
Now that THAT is out of the way. I will start at the beginning. When I Powered on the PC for the first time, it did not power on at all. After a "paperclip trick" and a new PSU cord, it powered on. I quickly discovered that the ram was being clocked at 1333Mhz and not 1600Mhz. I manually went in and fixed the Ram clocking issue in the Bios, switching it from Auto to 1600Mhz. After a reboot, It showed it being clocked at 1600Mhz, I switched it back to Auto and from then on it always clocks it at 1600Mhz like it should (not sure what that problem was or if it was even a real fix, but it is "fixed")
Anyhow, The next issue I had (and still having), is that the Bios boot info screen says that I have no HDD, Yet the Bios config shows it plan as day... as well as windows. I gave up on fixing that issue and continued with Installing Windows 7. Everything went fine. I set it all up, I got all my programs and games downloaded and set up... and then the real problem started. Any demanding game that I play (Star Wars: The Old Republic, Battlefield 3, Rift, Skyrim, ect) will run fine and flawless for about 15 minutes and then my PC will power down, as if someone unplugged it. Sometimes it will reboot but I would say that 65% of the time it shuts off with out a reboot. It does not shut off with less demanding games such as (Wakfu, League of Legends, World of Warcraft). I even ran a FurMark Burn In Test successfully for an hour with out any issues. Everyone says the same thing, that it is either the GPU or CPU over heating, well it is not. The CPU never gets higher than 79 on load, and the GPU never gets higher than about 77 on load.
My PSU is placed on the bottom of my case with the fan facing down into the base vent, I thought it could be over heating due to lack of air flow into the PSU as the case "feet" do not sit the case very high off the desk, So I flipped it over for more air flow and I get the same results. So assuming I replaced the PSU, What would be the next suggestion? I'm at my limit of computer knowledge to be able to even guess as to what it could be, beyond a crappy PSU. Could it be a safety setting set too low in the Bios? Ive heard of people having that issue as well, but I have no clue as to what the voltage on everything should be, and don't believe shutting off the UVP/OVP would be a smart move.
Thank you in advance to anyone and everyone that could shed some light onto this issue.
CPU - i5-2500k
