Tom's Hardware > Forum > CPU & Components > Sound Cards > Still need help solving this problem
hey guys i need serious help, heres my rig hope someone could help me with my problem
AMD 1.2 (not oced) CPU heat idles at (48-49) and (52-53) under load
A7V133 (Bios 1004)
Asus geforce2 V7700 GTS (latest detenator drivers from nvidia)
SB live X-Gamer (latest drivers from creative)
Kingston NIC card (latest drivers)
Via4in1 driver 4.29v
promise ata100 driver updated
300watt AMD approved PSU
Ok problem is I keep freezing when im playing counterstrike. Sometimes it takes 30 min or an hour but i eventually will freeze. I have tried every setup but cant fix it. First I thought it was a IRQ conflict i looked into that and found out that sb live was sharing IRQ with NIC card, so i moved SB live to PCI slot 3 and assigned it to IRQ 5 by itself. And the NIC card is on slot 4 sharing IRQ with USB controllers. If I change the IRQ for the NIC card the USB controllers move with it. So I disabled COM 3 and assigned NIC card to IRQ 3 sharing with USB controllers.
heres setup
00 sytem timer
01 standard 101 microsoft natural keyboard
02 programmable interrupt controller
03 Kingston EtheRX PCI 10/100 Fast Ethernet Adapter
03 VIA tech 3038 PCI to USB Universal Host Controller
03 ACPI IRQ Holder for PCI IRQ Steering
04 Communications Port (COM 1)
05 Creative SB Live! series
05 ACPI IRQ Holder for PCI IRQ Steering
06 Standard Floppy Disk Controller
07 ECP Printer Port (LPT1)
08 System CMOS/real time clock
09 SCI IRQ used by ACPI bus
10 Win 95-98 Promise Ultra100 IDE Controller
10 ACPI IRQ Holder for PCI IRQ steering
11 NVIDIA Geforce 2 GTS/ Geforce2 Pro
11 ACPI IRQ HOlder for PCI IRQ Steering
13 Numeric data processor
14 Via Bus MAster PCI IDE controller
14 Primary IDE controller (dual fifo)
15 Via bus master pci ide controller
15 secondary ide controller (dual fifo)
I have also learned that slots 4/5 automatically use IRQ for USB controllers, slot 1 uses video card, and slot 2 uses promise ata100. So that leaves me only slot 3 to use, I dont know if its the NIC card and the USB controllers causing the problem or Sound card. I forgot to mention i have a USB microsoft optical mouse which might cause problems with the NIC card. Its either Sound card with USB controllers or NIC card with USB controllers. And i have tried both setups and both dont work. I cant use slot 2 because of the ata100 and slot1 is used by the video card. I have tried looking for a way to change the USB controllers to a different IRQ but cant find it. Anybody know if this is possible on the A7V133 mobos??? Also I have done some tests to see if it was a heat problem runining seti@home and comp was doing fine. And did a test on 3dmark and passed all tests. Dont know what else to do, I hope someobody out there can find the problem.
THANK YOU FOR ANY HELP
Sponsored Links
Heyya ...
I have a similar problem to you, my rig looks like this
- T-Bird 800 (Runs at 60 deg ... ouch)
- SB Live DD/Phillips Accoustic Edge
- A7V - 1004
- TNT2 M64 (sighs)
I also experience freezes and lockups in Counterstrike (everything else runs perfectly, eg UnrealT). When I switch to OpenGL (instead of Direct3D) everything runs perfectly (had an 8 hour gaming session the other day).
I don't think your problem is IRQ/setup related, if it was, you system would freeze a lot sonner than 30 minutes.
Reply to Anonymous
There are 711 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
