Themes problem SP2
Last response: in Windows XP
Archived from groups: microsoft.public.windowsxp.customize (More info?)
Hello
My problem is this. I have tried changing the desktop
theme in SP2, but the only thing that changes is the
wallpaper, and the desktop icons. The taskbar at the
bottom of the screen just changes color to match the
theme, but it doesn't change the font type, or other
properties associated with the theme. These are themes
that worked perfectly until today. When I right-click on
the desktop, and go into properties, and then appearance,
somehow, it has reverted back to Windows Classic Style.
When I then change the appearance to the same type as the
theme installed, and click on apply, it doesn't change.
This happens with all the themes I have installed. Is
there a way of changing some kind of settings that will
allow all the properties of a theme to be installed, and
not just parts? Or, could there be a program installed,
that is causing this problem? If anyone needs any further
information, or has any questions, please contact me.
Again, these are themes that were installed, and worked
Any help would be greatly apprciated.
Neo
More about : themes problem sp2
Neo rambled on in microsoft.public.windowsxp.customize:
> Hello
> Neo
Are the themes custom ones you downloaded from a web site? If so then you
need to patch your uxtheme.dll file, do a google search for patch
uxtheme.dll sp2.
Ask the community
