Solved
First build need help
Last response: in Systems
i relly need help on this build i need new computer nd dont yell t me becuz the letter below q wont work on my keybord. but go figure. id like suggestions on wht im doing wrong but im tryin to go under 800 on this one if you could plzz help me out on this one.
cpu intel i5 2500k http://www.tigerdirect.com/applications/SearchTools/ite...
motherbord gigbyte http://www.tigerdirect.com/applications/SearchTools/ite...
hdd wd 750gb 7200rpm http://www.tigerdirect.com/applications/SearchTools/ite...
gpu geforce gtx 560 ti http://www.tigerdirect.com/applications/SearchTools/ite... or 6870 http://www.tigerdirect.com/applications/SearchTools/ite...
psu coolmx 400 wt http://www.tigerdirect.com/applications/SearchTools/ite...
memory corsir vengnce 2x4gb 8 http://www.tigerdirect.com/applications/SearchTools/ite...
shell ridmx torndo http://www.amazon.com/gp/product/B0059205CW/ref=ox_sc_a...
More about : build
Homebuilt system Master
What is the computer primarily going to be used for.
The motherboard is fine, the HD is fine, you can probably do without the sound card.
Other stuff I will change after you tell me the sorts of things that you will be doing on the computer, most likely.
Related ressources
Best solution
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I52500K - $230
GIGABYTE GA-Z68MA-D2H-B3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard - $108 (338)
Crucial 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory Model CT2KIT51264BA1339 - $40 (378)
COOLER MASTER Elite 430 RC-430-KWN1 Black Steel / Plastic Computer Case - $40 (418)
XFX Core Edition PRO550W (P1-550S-XXB9) 550W ATX12V 2.2 & ESP12V 2.91 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply - $61 (479)
Seagate Barracuda ST500DM002 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive - $85 (566)
XFX HD-695X-ZNFC Radeon HD 6950 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity - $224 (790)
That gets you under $800 for the full system.
I really would have liked to have another $100 to feel good about this because I had to make a lot of sacrifices I really didn't want to make to get it under the budget.
In any event, it should still perform very well. I am just not happy with the hard drive, the case, and it really would have been nice to get an ATX motherboard instead of a micro board.
With $100 more I could have gotten the part I wanted for each of those.
Ask the community
