Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Nvidia > Wrong Native Resolution on my Monitor
Forum Graphics & Displays : Nvidia Wrong Native Resolution on my Monitor
Hello, to start off I am running a Nvidia GTX 560 graphics card in a HP Pavilion a6742p PC. I am running a dual monitor set up and just bought a new second monitor. My first is a HP w2207. The new second monitor I am running is a LG Flatron E2241 and after setting it up and installing the drivers from the disk that it came with I am unable to adjust the resolution properly. The maximum resolution of the screen is 1920x1080, however when I try to adjust it in both the Nvidia control center and my computers control panel the only options are 800x600 and 1024x768. I'm running 32 bit color scheme and a 75 hz refresh rate.
I have tried: rebooting, making sure graphics drivers and monitor drivers are up to date. Lowered resolution of one monitor to see if there was an over all limitation that I had reached and it had no effect. My previous monitor ran at a high resolution with absolutely no problem and this is beginning to be extremely frustrating.
Reply to Colechadwick66
for lcd you dont have to run 75 hz go down to 60 hz,ajust the resolution in nvidia control panel for each monitor,like the hp w2207 the set the second the lg e 2241 but you have to see them as two display in the panel
Reply to scout_03
I have tried running at 60 hz with no change. In the Nvidia control panel I have the lg set up as my second monitor and it still is only giving me two options. Although it is only recognizing my lg monitor as "Digital Display" instead of the name of the monitor, could this be part of the problem?
did you put the driver for the monitor
Reply to scout_03
There are 2178 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Will this video card work on my PC..
By looniam, 4 hours ago:
no need for power connections and your PSU is ok to go with it...
Best offers
Top experts
