Hi All,
The other day I decided to do a new system build, thought it would be simple enough as I have done a couple builds before but none from complete scratch.
I decided to go for the following spec all bought off of Novatech who have always served me pretty well, I didnt want a ultra performance machine but something which I can easily upgrade in the near future.
The spec is as follows:
Intel Core i5 2400
ASUS P8H67-M PRO MOTHERBOARD
NOVATECH COUGAR ATX CASE with 500W Novatech PSU
SEAGATE 7200.12 500GB 6GB/S
CORSAIR VENGEANCE BLUE 2X2GB DDR3
LG GH22NS70 22X DVDRW OEM
So all the parts arrived within two days so I was chuffed with that, unboxed everything and pieced it all together without any issues.
I then tried to boot the PC and thats when my troubles started! The motherboard power LED lights up so the Mobo definatley has power going to it. My first thought was that the power button on the case was faulty or connected wrongly to the mobo however I checked this and all seems fine.
On further investigation when I press the power button both the CPU fan and PSU fan move slightly as if they are trying to start up. This leads me to a Power supply issue, I have another power supply on its way to try so i am hoping that will resolve the issue and will keep you guys posted, but before that does anyone else have any suggestions for me?
Thanks in advance!
Intel Core i5 2400
Thanks in advance!
