So I have been playing around with building a new gaming pc for a little bit and finally have most of the components figured out.
I am not going to be buying all at once to alleviate the strain on the wallet, but I would like to know what you guys think about these components together so I can start looking for deals.
I also have a couple specific questions for some components.
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021&Tpk=750%20tx%20v2&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=17fr9aft5lm3e
(corsair 750W)
CPU: i5 2500K
MOBO: asrock z68 extreme 3 http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271
Ram: ripjaw 8gb http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=12obsj8ovx6no
GPU: gtx 570 superclocked http://www.newegg.com/Product/Product.aspx?Item=N82E16814130595
OK so....
1. will that case fit the gtx 570..that thing is huge
2. psu good for sli in future?
3. Do i need additional fans
aslo...i will have a tri monitor set up...one for gaming , but 3 when I am surfing the web writing papers etc. I was wondering how does this work with the built in z68 gpu?
Do i need additional cooling, I do plan on overclocking in the near future.
and finally I will be buying the hard drives lastly, any recommendations?
thank you guys so much best place on the web for advice!
(corsair 750W)
CPU: i5 2500K
OK so....
