Arctic Silver 5, I've heard, is the best thermal paste around. I will purchase some from Amazon, but I would like to know what the difference is between ones with "3.5g" or just "3.5" in their title.
For example, this one with "3.5g," http://www.amazon.com/Arctic-Silver-Polysynthetic-Thermal-Compound/dp/B0002VFXFE/ref=sr_1_1?s=electronics&ie=UTF8&qid=1337387892&sr=1-1
Versus
This one without "3.5/g" in its title:
http://www.amazon.com/Arctic-Silver-5-Thermal-Compound/dp/B0002EQU6C/ref=sr_1_3?s=electronics&ie=UTF8&qid=1337387892&sr=1-3
Well, it's probably a very ignorant question on my part, but I would also like to know, how does the thermal paste work?
My father, me being only twelve years old, makes all the "executive" buying decisions, and strongly believes thermal paste is not necessary. I believe otherwise, and I know it is crucial to transfer heat from the CPU to the heatsink. But, that's all I know. How exactly does it work? My father's argument is "Jason, metal against metal are the best heat conductors. Placing an organic material between them would make them perform worse, if not the same." Usually, I would not argue with my father, but I'm beginning to surpass him, even if I am twelve years old. I've built a computer, know the ins and outs of the computer, but both he and I still have much to learn.
Alright. After I purchase the paste, I'm obviously going to remove the existing heatsink/fan and use Isopropyl Alcohol 70% (it's the best I've got) to remove the current thermal compound. Then, apply Arctic Silver 5 on the cpu by squeezing a little grain of rice amount and spreading with a business card. Finally, put it together. So, here are the steps I am taking, please check if they're correct:
1. Remove heatsink. Unlatch the "cam" hook and turn the heatsink clockwise and counter-clockwise to break thermal seal. Pull vertically.
2. Clean CPU and Heatsink of thermal compound, using Isopropyl Alcohol 70%.
3. Apply AS5. Squeeze grain of rice amount and spread with credit card.
4. Put heatsink back on, latch the "cam" hook securely.
5. Check connections.
Thanks, I'm looking forward to all your answers!
- Jason
Versus
- Jason
