Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > [Solved] Is this PC build compatible with its parts?
Forum Systems : New Build [Solved] Is this PC build compatible with its parts?
Best answer from rvilkman.
Aprox Purchase date: Not anytime soon, Around October - December 2012
Budget Range: $800-$900
System Usage: Occasional Gaming (like tf2, Combat arms), Surfing the net, Working on Projects
Parts Not required: Keyboard, Mouse, Monitor, Speakers, OS, Cables and Wires for MT
Preferred Site of Purchase: NCIX.com
Country:Canada
Parts Preference: Don't care that much, as long as company is reliable and shows results :)
Overclocking: No
SLI or Crossfire: No
Screen Resolution: 1920 x 1080
Additonal Comments:
Before buying my components, would want to make sure they work together.
Motherboard: Gigabyte P67X-UD3-B3 ATX LGA1155 P67 DDR3 3PCI-E1 2PCI 2PCI-E16 CrossFireX SATA3 USB3.0 Motherboard
http://ncix.com/products/index.php?sku=60747
CPU: Intel Core i5 2500K Quad Core Unlocked Processor LGA1155 3.3GHZ Sandy Bridge 6MB
http://ncix.com/products/index.php?sku=57962
Computer Case: Corsair Carbide Series 400R Mid-Tower Case ATX 4X5.25 6X3.5INT USB 1394 No PS
http://ncix.com/products/index.php?sku=61928
Memory: Patriot Sector 5 PGV38G1333ELK 8GB DDR3 2X4GB DDR3-1333 CL 9-9-9-24 1.65V Dual Channel Memory Kit
http://ncix.com/products/index.php?sku=54174
Hard Drive: Seagate Barracuda ST31000524AS 7200.12 1TB SATA 32MB Cache 3.5IN Internal Hard Drive OEM
http://ncix.com/products/index.php?sku=58746
Graphics Card: AMD Radeon HD 6850
http://ncix.com/products/?sku=4746 [...] TECHNOLOGY
Power Supply: Corsair Professional HX650W 650W ATX 12V 52A 24PIN ATX Modular Power Supply Active PFC 120MM Fan
http://ncix.com/products/index.php?sku=42532
Message edited by MalcolmLX on 02-03-2012 at 09:59:47 PM
Get memory with 1.5V CAS9 1600Mhz instead of the one listed.
Gskill RipjawsX 2x4GB 1.5V CAS9 1600Mhz $57.20
or
Corsair Vengeance 2x4GB 1.5V CAS9 1600Mhz $57.13
You also might want to get a DVD burner.
And maybe an aftermarket HSF since you are getting i5 2500k for overclocking.
Cooler Master Hyper 212 + or EVO will do nicely and should be pretty cheap.
Otherwise they are compatible.
Best answer
or
Reply to rvilkman
Okay, great to know these will work.
And dvd burner? As in burning CD's?
Or for another use?
Reply to MalcolmLX
burning DVD's CD's and generally just installing windows for example.
They are about $20-30 so not overly expensive, just something which would be good to have.
Reply to rvilkman
Mhmm, Selected a relatively cheap DVD burner, I am pretty much set then!
Thank you very much for your help! :D
Reply to MalcolmLX
Get a intel i5 2400 save some money if your not over clocking
Reply to ToKiiNzSo1337
And this is still compatible and run properly with my other components?
Reply to MalcolmLX
or
There are 2119 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
$650 dollar budget 'gaming' rig. Can you help?
By geofelt, 1 hour ago:
To answer your question, an aftermarket cpu cooler is not necessary with a 2100. For $5...
Best offers
Top experts
