My question battery is bad?
Last response: in Components
Hello, since my notebook Acer AS11B5E,17 “the screen has fallen, I do not look at the demonstration nearly, if I connect it the exterior monitor, all demonstrated that I carry on me through each method to know (FN + F8, from control panel hand regulation) futile effort, integrates on display monitor's darkness, I am waiting for in this aspect advantages opinion, if my question battery is bad
.http://www.rubattery.com/acer.html
More about : question battery bad
Monitor Authority
Notebook screen stays dark. External/exterior monitor also does not work.
Shine flashlight or hold screen near bright light. Can you see dim display?
If no, probable cause is failed graphics chip on motherboard.
Ask the community
