yet... it USED to do up to 3900mhz (Turbo boost).. now it either does 1600mhz or 3700mhz, not even 3500mhz. Kinda weird. Must have been a setting of some sort but I don't know what?
You have to tweak the settings in the bios to get it exactly wehere you want it , if you dont want it dropping to 1600 you gotta remove the speed stepping and adjust the turbo ratio manually to where you want it to peak.
