Does this computer fits a 400wt Power Supply??
Last response: in Components
May 19, 2012 3:10:01 PM
Intel® Core™ i5-2400 3.1GHz Processor
GIGABYTE P61A-D3 - socket 1155
kingston 4gb ddr3 bus 1333mhz cl9 v1.5
Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s
Sapphire HD 7850 OC 2GB DDR5
400wt Power Supply here:
http://www.egprices.com/product.php?id=10631
a b ) Power supply
May 19, 2012 3:32:43 PM
I wouldn't, that's cutting it close and i doubt that psu put's out a true 400w. They don't even list the amps.
It would have been cheaper in the long run to buy a case and a separate psu.
There was another thread where this guy has a 450w BFG 80+, I told him he was fine, but I wouldn't recommend using that CM.
m
l
a c 243 ) Power supply
May 19, 2012 3:54:17 PM
WR2 said:
Cooler Master Elite 371 website.
http://www.coolermaster.com/product.php?product_id=6692
--> Cooler Master Elite 371 doesn't usually come with a power supply.
What do you know about that PSU in the listing?
Thermalmaster, bad, very bad
420w here
http://imageshack.us/f/209/18122011002.jpg/
Looks like they may be using the Coolermaster brand name now
Notice the psu is still a PSAR-13
m
l
May 19, 2012 4:36:43 PM
thnx guyz for replying.. so your saying I buy separate case and power supply?? if I did so what do you recommend and being cheap at the same time..
and please use cases and Power supplies from this site: http://www.egprices.com/category.php?cat=1
as I live in egypt and that's what I can get.. thanks again :)
m
l
a b ) Power supply
May 19, 2012 11:21:30 PM
Agreed
m
l
May 19, 2012 11:26:14 PM
thnx man :)  I don't want to be annoying but can you choose a case for me? :D  cheap one and good for cooling and letting this gpu work.. look is not important.
m
l
May 19, 2012 11:53:16 PM
Ohhh thnx very much :)
m
l
a b ) Power supply
May 20, 2012 4:29:38 AM
Quote:
The lowest price I can find at that store that Im willing to suggest is this:
CORSAIR CX430 V2
http://www.egprices.com/product.php?id=11789
I second that... best decent PSU there is. i hear that Corsair sells them at cost to work the lowend of the market. (they know you will buy one of there bigger more costly PSU's when you upgrade)
m
l
May 20, 2012 7:34:38 AM
^ thnx
m
l
May 22, 2012 7:00:10 AM
I'm sorry.. but in the sapphire site system requirements for HD 7850 OC 2GB, it said "500 Watt Power Supply is required."
is that true?
m
l
a c 139 ) Power supply
May 22, 2012 8:47:48 AM
It's true.
And CORSAIR CX430 V2 is roughly equal with a budget brand 500W PSU. It will have enough power for your parts.
m
l
May 22, 2012 9:30:51 AM
oh thank you :)
m
l
