Closed Solved
Buying New System - Wondering about issues
Hey, I'm new to this forum. I recently have been considering purchasing a new system. I want to connect it to a 27" monitor which I have. Therefore, the native resolution of games would be 2560x1440, I was just wondering if I would encounter any issues with the following specs:
CPU: Intel Core i7 2600 Quad Core CPU, 3.4 GHz
Motherboard: Z68 Chipset Motherboard
RAM: 8GB (2 x 4GB) Dual Channel DDR3
Video Card: AMD HD6950 2GB 256-bit GDDR5 PCI-E 2.1/2.0/16x 800/5000MHz, DVI / HDMI / Display Port, DX11, Fan
PSU:650W
If anyone could give me an idea of how Shogun 2 TW would run that would be helpful (given the demanding nature of this game). Thanks!
11 answers Last reply Best Answer
More about buying system wondering issues
  1. you could go with an i5 cpu unless you really have a need for the i7. i5 2500k is very nice :)
    Shogun 2 would perform great on a system like this.
    If you need help with picking brands and finding best prices. Just let us know :)
  2. This is basically a prebuild from http://www.ebay.com.au/itm/INTEL-Core-i7-2600-GAMING-COMPUTER-PC-8GB-1TB-HD6950-2G-/230631608807?pt=AU_comp_dekstop&hash=item35b2b711e7#ht_11404wt_1186 with the H67 altered to a Z68. I have never built a PC before but from what I gather I could save some money. If you really would like to help, I'd love if you could help find the best prices for such a system. However I would like an i7 CPU :D. Thanks for your quick response ;)
  3. What is your budget and do you live near a Micro Center?
  4. Budget is about 1400-1500. I live in Australia (probably very far from a micro center haha!), so online retail/delivery is probably the best option.
  5. Actually I just noticed your res requirement; you may need a better GPU to play Shogun 2 on high. Let's get a second opinion on that one.
  6. $1400-$1500 US Dollars?
  7. AUS which is slightly higher. So US is fine :D
  8. Best answer
    kk Here is a starter parts list with Newegg prices.
    i5 2500k (i7 isn't that much better for gaming) $22
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072&Tpk=i5%202500k
    P8Z68-V Gen3
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131790
    8GB RAM I like these (but look for the best brand/price in your area)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820233186
    HDD are a crap shoot with prices. You have to pick the size you want and a few brands and watch prices here. I am not even including one in my newest build, just using a 128GB SSD until prices come back down.
    GPU- here's one that you mentioned, but we need that second opinion here
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814102945
    PSU- OCZ ModXStream Pro 600W Modular or better
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817341017
    Case is subject to taste and budget but here is a nice budget one
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
    For a bit more, I like:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811139006&Tpk=650d
    Any reputable optical drive
    A cpu cooler to budget
    less expensive, but not as cool
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
    or a bit more but cooler (= higher OC depending on the chip)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835181015&Tpk=h60
  9. Best answer selected by Thrallsman.
  10. Thanks for your help. Did a bit of research and found that the 6950 is more an excellent card for high resolutions, due to its memory. Turns out the cost of the prebuilt off ebay is the same as your suggested build (+an SSD), with the addition of the i7 2600k over the i5 2500k. So for once, I think a prebuild may actually be a better option. Thank you for your help!
  11. This topic has been closed by Mousemonkey
Prebuilt Systems Product
