Update to $800 system w/ monitor build
Posted quickly any tips will be appreciate try to ignore the super saver crap lol some items only have a few left in stock so im hoping to buy tonight Thanks :D
Kingston HyperX 4 GB Kit (2x2 GB Modules) 1333 MHz DDR3 Desktop Memory KHX1333C7D3K2/4GX - Kingston H. Corporation
Only 10 left in stock--order soon (more on the way).
Eligible for FREE Super Saver Shipping
This will be a gift (Learn more)
Delete · Save for later
$29.99
You save:
$44.00 ( 59%)
Raidmax Altas ATX Mid Tower Case ATX-295WB - Raidmax
$49.99
You save:
$3.57 ( 7%)
Corsair XMS3 4 GB 1333MHz PC3-10666 240-pin DDR3 Memory Kit for ... was removed from Shopping Cart.
AMD FX 4100 4-Core Processor, 3.6 4 Socket AM3+ FD4100WMGUSBX - AMD
In Stock
$109.99
You save:
$20.00 ( 15%)
Asus 24xDVD±RW Serial ATA Internal OEM Drive DRW-24B1ST (Black) - Asus
In Stock
$22.88
You save:
$2.56 ( 10%)
XFX ATI Radeon HD6770 1 GB DDR5 VGA/DVI/HDMI PCI-Express Video Card HD677XZNLC - XFX
In Stock
$109.99
You save:
$58.75 ( 35%)
Corsair Builder Series CX V2 500-Watt 80 Plus Certified Power Supply Compatible with Intel and AMD Platforms - CMPSU-500CXV2 - Corsair
In Stock
$57.74
You save:
$12.25 ( 18%)
Asus Socket AM3+/ AMD 970/ Quad CrossFireX/ SATA3&USB3.0/ A&GbE/ ATX Motherboard (M5A97) - Asus
In Stock
$94.99
You save:
$11.81 ( 11%)
Acer G205HV bd 20" Class Widescreen LCD Monitor - Acer
In Stock
Shipped from: CircuitCity
$89.99
Windows 7 Home Premium SP1 64bit (Full) System Builder DVD 1 Pack - Microsoft Software; DVD-ROM
In Stock
$99.99
You save:
$20.00 ( 17%)
Seagate Barracuda 7200 500 GB SATA 6.0 Gb-s 16 MB Cache 3.5-Inch Internal Bare Drive ST500DM002 - Seagate
In Stock
Ships in Certified Frustration-Free Packaging
1 answer Last reply
More about update system monitor build
  1. Do *NOT* get a Raidmax case - they are not the best quality cases on the market. For an extra $10.00 you can get one of the best cases on the market in it's price range: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
    And then get the 960T over the FX 4100 - it will save you a ton of installation hassles because of the BIOS upgrade that's required before install. Try this instead: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103995
    And then for the RAM get 8GB - 4GB won't get you very far these days and can be had for an extra $20: http://www.newegg.com/Product/Product.aspx?Item=N82E16820178382
    Other than that it looks good. But definitely take those suggestions into account. And you should read up on FX before buying, start here: http://www.tomshardware.com/reviews/windows-7-hotfix-bulldozer-performance,3119.html
New Build Systems Product
