1400$ Gaming PC Need Advice and Help
First let me say i am a Complete Beginner at this.
Approximate Purchase Date: (within 2 weeks)
Budget Range: 1400$ total
System Usage from Most to Least Important: (Gaming, surfing the internet Listening to music
Parts Not Required: Mouse and Keybored
Preferred Website(s) for Parts: Newegg.com (if possible all the parts need to be from here if not oh well lol)
Country: USA
Parts Preferences: Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core (what my friend tells me to get) a Full HD WideScreen LCD Monitor 21.5"
Overclocking: No(i have no idea how and don't want to break anything)
SLI or Crossfire: I don't know is it needed?
Monitor Resolution: 1920x1080
Additional Comments: it needs to be able to stay cool i play games alot and my current one gets hot as hell
Ive never built a gaming pc before or a normal one at that, i got these parts on the info i got from my friend and i don't know if there compatible, i need Info, advice, and anything else you can offer and a big thank you for your help.
This is what i have so far.
XCLIO A380COLOR Fully Black 1.0 mm SECC / ABS Plastic ATX Full Tower Computer Case
www.newegg.com/Product/Product.aspx?Item=N82E16811103033
ASUS P8P67 PRO (REV 3.1) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
www.newegg.com/Product/Product.aspx?Item=N82E16813131771
EVGA SuperClocked 012-P3-1573-KR GeForce GTX 570 HD w/Display-Port (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
www.newegg.com/Product/Product.aspx?Item=N82E16814130620
Rosewill RP600V2-S-SL 600W ATX12V v2.01 SLI Ready Power Supply
www.newegg.com/Product/Product.aspx?Item=N82E16817182032
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I52500K
www.newegg.com/Product/Product.aspx?Item=N82E16819115072
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
www.newegg.com/Product/Product.aspx?Item=N82E16820231314
Western Digital Caviar Green WD10EADS 1TB 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
www.newegg.com/Product/Product.aspx?Item=N82E16822136758
Acer G215HVAbd Black 21.5" 5ms Full HD WideScreen LCD Monitor 200 cd/m2 20,000:1 Max (ACM)
www.newegg.com/Product/Product.aspx?Item=N82E16824009306
LITE-ON DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model iHAS124-04 - OEM
www.newegg.com/Product/Product.aspx?Item=N82E16827106289
Microsoft Windows 7 Home Premium SP1 64-bit - OEM
www.newegg.com/Product/Product.aspx?Item=N82E16832116986
Creative Inspire T3130 2.1 Speakers
www.newegg.com/Product/Product.aspx?Item=N82E16836116048
And again im new at this and don't know if these parts go with each other and if i need to replace a part or start over, any help you guys can offer will be a life saver. i forgot to add I'm wanting to play Battlefield 3 on ultra with this rig
10 answers Last reply
More about 1400 gaming advice help
  1. @ the OP A few obvious changes I can see.
    1) That HD is dirt slow
    2) That Asus mobo is already outdated and is meant for a dual card set up. You want a Gen 3 board that supports PCI-E 3.0
    3) That Rosewill psu is complete junk
    4) This new PCI-E 3.0 vid card down below out performs the gtx 580 and does it for cheaper
    5) I would look at a better brand/manufacturer for a case
    Look at making these changes...
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813157279 $104.99
    ASRock Z68 PRO3 GEN3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013 $69.99 - $54.99 after mail-in rebate card
    XFX Core Edition PRO550W (P1-550S-XXB9) 550W ATX12V 2.2 & ESP12V 2.91 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840 $124.99
    Seagate Barracuda ST1000DM003 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119240 $89.99
    COOLER MASTER Storm Enforcer SGC-1000-KWN1 Black SECC / ABS Plastic ATX Mid Tower Computer Case ATX PS2 / EPS 12V (optional ) Power Supply
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814102962 $449.99
    SAPPHIRE 11196-00-40G Radeon HD 7950 3GB 384-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099 $34.99
    COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible with latest Intel 2011/1366/1155 and AMD FM1/AM3+
  2. @Why_me
    Ive made the changes to the parts you suggested and i am still researching but if i get that case ill be over my budget so i was wondering if This Case would work or if i need to look for a better one www.newegg.com/Product/Product.aspx?Item=N82E16811144259
    PS.i have a Headache this is confusing lol :pt1cable:
  3. Vanhight said:
    @Why_me
    Size is what kills that case. Other than the 560 series cards, most of these newer cards are as long as a boat, not to mention you want to be able to fit a cpu h/s, fans, etc...
    For a great budget case with size this CM down below is tough to beat. Cooler Master has lots of LED fans you can add to it later on...like a side 200mm LED fan...Amazon has them in red and blue for around $13 + free shipping...newegg is a few dollars more.
    http://www.amazon.com/Cooler-Master-Tower-Case-RC-912-KKN1/dp/B003ZM7YTA/ref=sr_1_4?s=pc&ie=UTF8&qid=1328391477&sr=1-4 $59.99 & this item ships for FREE with Super Saver Shipping
    Cooler Master HAF 912 Mid Tower ATX Case (RC-912-KKN1)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233 <---- same case on newegg
    Here's another case worth looking at. It's a bargain for $70 and free shipping.
    http://www.amazon.com/Cooler-Master-SGC-2000-KKN1-GP-Storm-Scout/dp/B00243HHNY/ref=sr_1_8?s=pc&ie=UTF8&qid=1328392021&sr=1-8 $69.00 & this item ships for FREE with Super Saver Shipping
    Cooler Master SGC-2000-KKN1-GP Storm Scout ATX/MATX/ITX Mid Tower Case (Black)
    http://www.amazon.com/Cooler-Master-Enforcer-Interior-SGC-1000-KWN1/dp/B004WK3KKQ/ref=sr_1_7?s=pc&ie=UTF8&qid=1328391477&sr=1-7 <----- Here's free shipping for that CM Storm Enforcer
  4. Vanhight said:
    Everything looks solid in that build. I didn't see a dvd writer/optical drive but you can pick a decent one up on newegg for around $20 - $25. Just make sure it's a SATA and not an EIDE hook up.
  5. @Why_me
    Would this work or is it the wrong kind?
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=199ki8obz3nrd it should have been the Second link, also my friend says that if i get that case i should get another 200mm fan? what do you think? if so can you suggest one?
  6. Vanhight said:
    @Why_me
    That burner will do just fine. :) If you can fit that 200mm fan in your budget then go for it.
    http://www.amazon.com/Cooler-Master-Computer-Cooling-R4-LUS-07AR-GP/dp/B002LE8BJA/ref=pd_vtp_e_1 <---- there it is on amazon, and newegg has it also.
  7. Ive got the parts and am ready to order, thank you so much for your help i would have been in a mess if it wasn't for your help :bounce:
New Build Systems Product
