After installing new Cooler for VGA, HDD problems
So....
After I installed new Accelero S1 Plus today (first blown out all the dust, cleaned whole case etc.), when I turned up my computer firsty... it would even boot up.. then i had to unplug and plug into other channel the 2nd HDD wcich then was shown as 2nd master HDD, and then i unplugged and plugged it again and so on and so on
and now i have 2 master drives....
but my problem is that the Windows 7 recognizes the drive, but only as one partition that is 33mb big -.- and the HDD is 1TB... and it says that i have to format the partition if i want to use it. How can Windows recognize the disk but only as one partition??
I unplugged the HDD and plugged it in in the other computer and it does the same thing(Win 7 also installed there) it recognizes it but as one partition 33mb big -.-
Can you please help me?
Thank you!
1 answer Last reply
More about after installing cooler problems
  1. PrPrO said:
    So....
    Thank you!
    Umm.. in Disk Managment it now sees 3 disks
    the 0 which is not initialized, that has 2mb, the disk 1 that should have 1TB but it sees only 32mb RAW and disk 2 which is master disk from windows and other stuff
Cooling Partition Hard Drives Components
