Hello i have very frustrating problem with my PC , I don't know the cause of it and it`s killing me day by day....because i'm unable to fix it.I will try to describe my problem hoping that someone can help me with this issue.
My PC specs :
CPU : i7 980x
MB: Gigabyte G1 Assassin
GPU: Gainward GTX590
RAM: KingSton HyperX cl8 1600Mhz - 12 Gb
SSD: KingSton HyperX 128Gb ( sATA3 )
2xHDD Seagata pipeline 2x1 TB ( i use them for storage )
Case: Antec twelve hundred
PSU : Corsair 1000W
My Problem :
For some time i have noticed that when i listen to music on youtube , or watch a movie on my pc ( any format ) some times for a short period like 1-4 sec/s my PC lags (trembles don`t know if this is the right term ) but i lags short and then it goes back to normal......and when it does ..the movies/video are distorted....the whole system lags ... and i have no clue on how to fix it because i don`t know what is cousin it , i don`t remember this to happen in games....,and yes when that happens the spiking i can see in task manager that my CPU usage jumps to 50-80% in the blink of an eye and returns to normal...it does that every time the spiking/lags appears ......and it`s just killing me...it make me sell my PC......
What I have tried and done so far:
Ok ..so...hear me out:
1. I have original windows 7 ultimate x64
2. I have already reinstalled my windows about 4 times and done this.
2a- Fresh install updated all the drivers from vendor website etc etc updated windows... ( my system is not in OC ) ..spiking occurred
2b- Fresh install the install the drivers from vendor ( old drivers , 1st release ) spiking occurred
2c Updated BIOS , fresh install...updated drivers ..etc etc spiking occurred
3. My system temperature is very low because i use water cooling , my cpu nerver reaches high temperatures , always below 35 and max 46 in full load.
4. I have not overclocked my system , and when i have done it ..was just for benchmarking and for a shot period ( i know how to perform safe an stable OC ..etc )
5. I have updated the ssd firmware since it was necessary for my model.
6.I have UPS 2000VA .....my system is always protected from high voltage and etc.
7.I don`t get blue screens ( i have BlueScreenView installed in case do..so i will know why )
8. I have done many test to my system :
8a - MemTest (in dos mode ) TEST OK
8b- CPU test with ( prime95 full load ) 2 days in test - TEST OK
8c- CPU test with Intel Processor Diagnostic Tool - TEST OK
8d- GPU tested with many - TEST OK
8e SSD with a tool from KingSton - TEST OK.......
9. All the software and games from my PC are original , i don`t use warez/pirated programs ore cracks.
10. Antivirus is use McAfee total protection 2012
11. I DON`T KNOW IS MY PROBLEM AND IT`S KILLING ME....
12. ACHI enable from bios and 64 bit mode , i have tried the IDE mode , but the spiking is still there.....
13. Sorry for my bad english ...
What i Suspect :
1. The SSD
2. The Power Supply
3. MotherBoard (not very sure )
I have tried taking my PC to a IT shop...turns out i have more info and knowledge then the guy there...and i can`t send anything for warranty because...i don`t know what ... #^T%$ it`s wrong.
CAN SOMEONE HELP ME ?
I cannot figure out what is the problem..and i don't think straight when i'm mad.......
Regards,
Artix
My PC specs :
CPU : i7 980x
PSU : Corsair 1000W
My Problem :
What i Suspect :
1. The SSD
2. The Power Supply
Regards,
Artix
