Help required :)
I have a computer guys.
i5 2500k 3.3Ghz
intel dh67cl motherboard
NO GRAPHIC CARD :sarcastic:
4 Gb DDR3 Ram'
1Tb HDD
which ups i should buy ? ( how many watts )
5 answers Last reply
More about help required
  1. Are you looking for a Power Supply Unit (PSU) to power your PC or a UPS (battery back-up and surge protection)? Do you intend on getting a graphic card?
    If you're not getting a graphic card, then a good 300-350W is more than enough for your PC. A couple of options:
    1. http://www.newegg.com/Product/Product.aspx?Item=N82E16817371033
    2. http://www.newegg.com/Product/Product.aspx?Item=N82E16817151085
  2. UPS? PSU you mean?
    This will be good enough for just a 2500k
    But it will have low upgradeability such as when you want to put a graphics card. If you want something that has good upgradeability get something like this:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013
    This will let you use cards like 670 or 7870
  3. If you mean PSU i recommend the CORSAIR Builder Series CX430 PSU, If you want something from a 6870 to a 7970 get a XFX PRO750W XXX Edition Semi-Modular PSU that may handle cards like the 690 although then you should look for a 850w or something...
  4. i am looking for a ups ( Uninterruptible power supply thingy , which makes your pc run for a certain time, when there is no power supply >_< ) for my pc.
    and i am also buying a graphic card ( Nvidia 560 ti ) soon , so suggest me something good :]
Power Supplies Graphics Cards Intel i5 Components Product
