Amd vision engine control center wont open
dbrown207
This has been the most effictive advise with getting my CCC to work, after uninstalling everything using the driver sweeper and all that, :
While UAC is turned off (Vista/7 only) navigate to the "C:\Windows\Assembly" folder and delete any assemblies which have the public token key "90ba9c70f846762e". It is possible that you won't find any, but check it.
Rjwaters147
46
YOU SIR ARE AMAZING, I have been non-stop searching for a way to open my CCC and this is the solution this must be told to many people because you have done wonders for me. Thank you so much. :D
