Will this ram, cpu, and motherboard all work together?
First off heres the motherboard - http://www.newegg.com/Product/Product.aspx?Item=N82E16813138283
CPU - http://www.newegg.com/Product/Product.aspx?Item=N82E16819103911
Ram - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231424
Alsoi have a gts 450 1 gb gddr5 pci express 2.0... this will work with it also right? Thanks everyone
3 answers Last reply
More about will motherboard work together
  1. Yes. I use that board with gskill 1333 ripjaws, and it works fine.
  2. What about the CPU and motherboard?
  3. No problem. The cpu is listed under "cpu support" on the board webpage.
Homebuilt RAM CPUs Motherboards Systems Product
