Help with my Radeon hd 6670
Ok i got a radeon hd 6670 and i i have windows 7. i installed the amd drivers but they dont show anywere in the computer or in my task bar. i looked in the device manager for it but all i found was the intel video card. How can i get my computer to read my video card and also i would like to add that i have the cd but it just stays in blank and i cant install the drivers from the cd.
please i need help with this if you need more information please let me know.
12 answers Last reply
More about help radeon 6670
  1. Remove both driver AMD and Intel. Then boot into safe mode and run Driver Sweeper and clean the remaining AMD and Intel graphic driver. Then, boot into Windows, and install the latest Catalyst 11.1 driver.
  2. yeah i did what you said and well it still wont work what should i do and when i go to install the amd manager it says everything is up to date but i dont see it anywere
  3. Did you try to play games? Did it have any problems?
  4. no i didnt try to play games i just tried to install the video card and well i downloaded the amd thing and when i did the set up it does everything except nothing happens actually i cant find the ccc and when i go to the device manager my radeon hd 6670 doesnt show up
    i really dont know what to do and i just want to finish intalling video card
  5. Ok, now install again, and select custom install. And checked what is not installed.
  6. it says that everything was installed correctly
  7. Try disable the integrated GPU in BIOS.
  8. ok and were in the bios can i disable the gpu? cause i cant find it
  9. Ok, what is your motherboard model?
  10. uninstall CCC amd through control panel program uninstaller
    restart
    before installing the amd driver
    make sure to install the Microsoft WDM driver for the card through
    microsoft update
    then restart the computer and install the AMD driver
  11. You can download Steam and use Steam to keep the drivers up to date - here: http://store.steampowered.com/about/
    If you're having problems beyond that then I'd suggest uninstalling Catalyst drivers through (1) "add/remove" programs in Win. 7 (2)driver sweeper to get the remnants - here: http://phyxion.net/Driver-Sweeper/Driver-Sweeper/Version-3-2-0/ (3) Temporarily disable anti-virus software and re-download CCC 11.11 and install... once installed you should be prompted to reboot - if not somethings wrong... once you reboot right click your desktop and CCC should be listed at the top...
    good advice
    I would just add in my experience dont install CCC with the generic VGA driver that first loads up
    use Windows Update to get the MS WDM driver for card
    reboot it
    and then install the CCC driver
Radeon HD Graphics
