Help me choose parts for gaming computer? 600$
Budget: 600$
Purchase date: today
Parts not needed: win 7, keyboard, mouse, speakers, monitor
Country: us
Usage: gaming
Overclocking : no but maybe for gpu
Sli/crossfire: no
Hey guys I want to get the best for my 600$. I had a psu in mind for 80$ but there was one for 60$ exactly the same on the same website. So help me.
I3 2100
Radeon 6950
Mobo: h61 cafe or http://www.newegg.com/Product/Product.aspx?Item=N82E16813157236&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=1emy9xu8k39ro
Hard drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16822145531
Ram: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231426
Psu: http://www.newegg.com/Product/Product.aspx?Item=N82E16817151096&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=12cmb8hx8kpim
Recommend me a case?
Recommend me a DVD drive?
Help me not surpass my budget and get the best out of 600$
25 answers Last reply
More about help choose parts gaming computer
  1. Someone help me?
  2. CPU: i3 2100 $124
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819115078
    This is a great CPU for $125, the only downside is that it is not overclockable, however, this is one of the best gaming CPUs on the market.
    Graphics: GIGABYTE GV-N560UD-1G GeForce GTX 560 Ti $210
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814125401
    The gtx 560Ti is not the graphics card you wanted, but it has similar performance to the Radeon 6950 and is also cheaper. It is definitely one of the better graphics cards you can get.
    MoBo: ASRock H61M-VS $55
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813157241
    This is a great budget board from a reliable company.
    PSU: OCZ ModXStream Pro 500W $65
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817341016
    This is a great PSU that is also modular. It is 80+ certified, meaning it'll energy saving.
    Case: NZXT Gamma $40
    http://www.amazon.com/GAMMA-Classic-Interior-Chassis-Black/dp/B002UDK9U6
    This is a great case for $40, you will not find another case with the amount of features the Gamma has. The Gamma was designed to be a gaming case and therefore you can fit 10" + graphics cards into its bay.
    HDD: Seagate Barracuda ST500DM002 500GB $85
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822148767
    This is a cheap HDD compared to the rest of the HDDs. It is also from a reliable company. I do not recommend going with any HDD that has a higher storage capacity than this since that'll bring the overall cost of the system up.
    RAM: Team Elite 8GB (2 x 4GB) Memory Model TED38192M1333HC9DC $37
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820313086
    This is a great RAM bundle. 8GB is overkill, although it is extremely cheap, and therefore won't hurt to add it. If you want, you can easily go down to 4GB of RAM without seeing your system suffer. I rarely use more than 3GB of RAM even when playing games.
    Heatsink+Fan: STOCK $0
    DVD-ROM: LITE-ON DVD Burner - Bulk 24X $18
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
    This is a very highly rated drive, it should do what you want it to. If you watch blu-rays then go with a blu-ray drive.
    Total $630
    The grand total (without Shipping and handling and rebates) is over your $600 budget, but there are multiple rebates and instant discounts that'll bring the system closer to $600.
  3. thanksforhelplol said:
    Someone help me?
    No Fear! Dragon has helped you :ange:
  4. your cpu is a bottleneck for your gpu. Drop down to this-http://www.newegg.com/Product/Product.aspx?Item=N82E16814102948 save you some money
    dvd drive plus cpu http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.822287
    case- http://www.newegg.com/Product/Product.aspx?Item=N82E16811146061 i have this and love it
    not sure about your board look for one thats h67 in your budget range
  5. Ok thanks so if I have a i3 2100 and a gtx 560ti... I'll oc the gpu a lil so what settings can I play on bf3 with 60 fps....? Also is this the best out of 600$?
    http://www.amazon.com/GAMMA-Classi [...] B002UDK9U6
    Looks like we can agree that the NZXT Gamma is a great case eh?
    Also, I really doubt the i3 will bottleneck the gtx 560Ti or the Radeon 6950. It's a powerful CPU that performs better than the FX-4100 in games. If you said it'll bottleneck with a FX CPU, I may have agreed, but I really doubt the i3 is going to be a bottleneck
    This is definitely the best you can go for $600 at regular market prices. You can do better if there were sales and such but we're not going to worry about that. As for BF3, I believe you can run it on Ultra at around 55-60FPS. I have a radeon 6870 (which is a step down from the gtx 560Ti) and it can run BF3 on Ultra with 2x MSAA at 45FPS and 60FPS with AA off
  8. Dragon thank you so much please check cause I'll post more and how will it run on swtor ultra what fps?
    No problem! If you need more help, you can also contact me via:
    http://www.roaringdragon.tk/contact.html
    or post on Tom's Hardware.
  10. What fps will swtor run on ultra?
    I personally cannot tell you what you will get. I assume it's going to be higher than BF3 because SWTOR is less system demanding
  12. Ok am I missing out on anything?
    Check my build..
    I3 2100
    Gtx 560ti
    H61 55$
    Gskill 8gb ddr3 Or the one u told me
    Seasonic 620w
    DVD comes with CPU
    Seagate hard drive
    Case u told me?
    Check my build..
    I3 2100
    Gtx 560ti
    H61 55$
    Seasonic 620w
    DVD comes with CPU
    Seagate hard drive
    Case u told me?
    It looks good although you can go down to the Seasonic 520W:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817151094
    That set up does NOT need 620W of power
  14. The seasonic 620w is 60$ cause of sale
  15. didn't notice that, ok. It's a ok! Go ahead
  16. The Seasonic PSU is better than the OCZ.
    The mobo the OP selected is also a better choice, having both USB3.0 and SATA 6Gb/s. The cheaper one saves $15 but gives both of them up; I'd rather have both, especially USB 3.0 if you ever think about using an external drive for backups.
    This 200MHz faster i3-2120 is also cheaper: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115077 at $120.
  17. Alright... Soo is this the best gaming setup for 600$?
  18. Yes.
  19. Difference for i3 2100 and 2120?
    The only difference is the stock clock. The i3 2120 has a 200Mhz higher clock than the i3 2100. Go with the i3 2120 because it's cheaper and has a higher clock rate, which may help in performance.
  21. Should I get the Eva gtx560ti 230$ or 210$ one ?
  22. EVGA has a lifetime warranty and is Nvidia's sponsored graphics card maker, go with EVGA since there is a mail in rebate that makes the total cost $215
  23. Ok roar so can I like play 60fps with i3 and gtx 560 ti on high? Also my resolution is 1920x1080 hp 23in
  24. I can play BF3 with a 6870 (which is a step down from the gtx 560Ti) at 45FPS on Ultra with 2x AA
  25. Hello, I was thinking to build this computer too but the motherboard and graphics card are out of stock. Are there any good replacements that will work with this build? Thanks in advance :) Sorry to bump this tread but it's my first time building a computer and I don't want to waste my money on things that won't work in the end...
New Build Systems Product
