Molex problem
Hey guys,
My pump for my reservoir wouldn't start so i had a close look and the molex plastic part fell off and the wings on the pins themselves are snapped what should i do ?
The reservoir is part of the xspc rasa rs360 kit.
2 answers Last reply Best Answer
More about molex problem
  1. Best answer
    If the unit is still under warranty, contact XSPC to RMA the pump/res.
    If the unit is not covered by warranty, replacing the molex pins is fairly easy. It can be done by crimping, soldering or both. Replacement pins are available through FrozenCPU
    those should work (buy two or three - especially if crimping), you should be able to reuse the plastic part.
  2. Best answer selected by danyon.
