Solved
Wireless problem due to gfx card
Last response: in Components
May 21, 2012 8:52:46 AM
Hey guys !
My current config is as follows:
Asus P8Z68 V-lx
i5 2400
8 GB Ripjaw
ASus 7850 DCUII 2GB
1TB hdd
600 W Great wall 7000A 80+ power supply
23" monitor
Dlink DWA 525 pci wireless card.
My problem is that as soon as i launch any application that is graphic intensive my wireless card stops working (either it will disconnect , or speed will go down very low to nearly 0) , and by graphic intensive i mean even while watching movies.
As soon as i close the application its working again
i have kept a slot space between the card and gfx card. but this is not alowing me to play games online .
Pls help
May 23, 2012 4:02:47 AM
come on guys 80 views but no replies!
i am not able to play any game online bcos of this!
the only doubt is , is it my wifi card problem or motherboard problem?
m
l
May 23, 2012 4:04:43 AM
i guess this was the wrong section to ask so have asked the same thing in networking section !
have any comments pls reply there!
m
l
Best solution
May 23, 2012 6:09:17 AM
Move the Wireless card as far from the card as you can, They sometimes will overheat. I have an Asus PCI Wireless card and the antenna is really long and I have most of it wrapped inside of my case, And I get some weird interference I think from my HDD's, Once I take the wire out of the case , it works like new.
May 23, 2012 6:16:39 AM
the gfx card and wireless card in the 1st and last slots
m
l
May 23, 2012 6:26:26 AM
Do you have a fan on the side of the case blowing towards the wireless and the video card? Might help, Other then that, It may just be a driver issue with it, Update the drivers, or downgrade the drivers and see if that will fix it. Btw don't use the windows driver for the wireless, Had a problem when win 7 installed my wireless card and some websites along with MagicJack would not work, but facebook and some games worked just fine.
m
l
May 23, 2012 6:27:49 AM
Also, What ISP do you go threw and what wireless modem/router do you use?
m
l
May 23, 2012 9:50:56 AM
nah i dont have a fan on side of the case but my graphic card hardly gets hot , its usually in the range of 35-40 or max 50 C . Also I m living in bangkok and i dont exactly know my ISP but i guess its true move and my router is thomson.
m
l
May 23, 2012 9:52:02 AM
as for drivers my wifi card has only one set from dlink and i m using that.
m
l
June 2, 2012 1:48:54 AM
Best answer selected by gaurang.
m
l
