Will the Radeon 6770 work with my motherboard and CPU?
After advice on another forum, I've decided to upgrade my Geforce GT 220 to the Radeon 6770 video card. My only concern now, is whether I'll see a noticeble improvement with my current motherboard and CPU:
Motherboard (I'm just typing all the information i get from CPU-Z, since i don't know what important):
- Model: Acer RS780HVF
- Chipset: AMD 780g
- Southbridge: AMD SB700
- LPCIO: ITE IT8718
CPU: AMD Athlon II x2 240, 2.80 GHz
Feel free to ask, if you need any more information.
Thanks in advance!
3 answers Last reply
More about will radeon 6770 work motherboard
  1. Yes it will be a drastic upgrade!
  2. Most all MOBO's will handle both AMD/ATI and Nvidia cards as long as you have a PCIe 16 on your MOBO. The upgrade is a big step and it should work providing your power supply will handle it. They have PSU calculators. here is an easy one to use. Good luck.
    http://educations.newegg.com/tool/psucalc/index.html
  3. Thanks alot! I was going to buy a Corsair 600W anyway :)
Graphics Cards CPUs Motherboards Radeon Graphics
