Heya,
Built my first computer since everybody has said that its probably the cheapest thing to do...but I'm not much of a technical wiz. So far everything is functional but I'm concern with the heat being generated by my cpu...
at idle it goes from 38c-45c and when in a game like skyrim, it heats up to 65c-75c ( This is with 4 fans running at Max speed.)
I'm upgrading the case to a full tower, perhaps its just the ventilation...also might just upgrade the stock CPU to a Noctua NH-D14 120mm & 140mm.
Hopefully that will cut out some of the heat...but still. I thought heat wouldn't be much of a concern since the system hasn't been overclocked.
Motherboard: ASUS P8P67 DELUXE
Cpu: Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) (Stock CPU Fan)
Memory: CORSAIR Vengeance 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600
Video Card: Nvidia GeForce GTX 580
Hard Drive: Seagate Barracuda ST1000DM003 1TB 7200 RPM SATA 6.0Gb/s 3.5"
Microsoft Windows 7 Pro 64 bit
CORSAIR Professional Series Gold AX1200
Fractal Design Define R3 Black Pearl Mid Tower (currently running 4 fans/ Will be upgrading to Thermaltake Level 10 GT Black Edition )
