hey all,
I'm having a problem understanding how I get the screws that you need to use to attach the fans to the radiator and then to the case to go all the way in...
when I try to install it on my case I put the washer on the outside of the case and thread the screw through the case then the fan and into the radiator hole. however trying to screw it in from there only allows a couple of turns leaving over half a cm of the screw and causing the fan and the radiator to be loose
anyone who has this know what I am doing wrong? and yeah I'm a novice
hoping to hear some feedback soon,
cheers,
Jesse
cheers,
Jesse
