I am looking into buying the XE's but I just wanted to ask you guys if it's a recommended buy given my setup. From what I understand they exhaust all their hot air directly back into the case and I am planning to get two.
Do you guys think it is going to cause significant overheating problems in my NZXT Phantom? Would the two 200mm fans up top and the 120 in the rear be able to exhaust the hot air quick enough for sli?
I am planning to put a sound card or tv tuner card right under one of them so will that cause significant overheating problems for the 580? Because in that set up the sound card/tuner card will end up covering one of the fans on the 580.
I am also going to have a h100 cooling a 3930k right on top of it so I was wondering if the hot air exhausted by these cards would greatly affect the cooling of my processor since the h100 rad will be mounted right under my top 200mm fans.
If it's not a viable then I might EVGA 3GB 580's since those exhaust out of the case. But from what I've seen many people can only overclock the core to about 850 whereas the XE's will overclock past 900.
Any input would be appreciated.
