So I've gotten myself a new system, everything was running fine except very seldom occurrence of my computer just shutting down by itself. (I'm still stuck with this issue).
I've went ahead an overclocked my processor (nothing major, voltage and everything on stock), ran test with prime and it was fine even after 15 hours of all 3 options.
It ran fine for a few days, until I wokeup one day to realize that I was unable to powerup computer. I've opened it up to observe the problem and I've realize that the first thing that happens is that the power comes on for about 0.5 seconds, fans spinning and stuff. But the power goes off and I am unable to power it up anymore. I've tried replugging the processor and mobo power, the same thing happens. Another point is that sometimes if I hold on to the power button for a slightly longer period of time, it boots up and works fine. (Ran for about 8 hours before I turned it off and went to bed.)
Things I've done are
Use the z68 onboard gfx instead of my 7970, same issue.
Use my old 8800gt, same issue.
Used a old psu, same issue (greater success rate with the random booting)
Using the old psu with the z68 gfx, same issue
Using the old psu with the 8800gt, same issue
Reseated the cooler fan (reapplied my thermal)
Computer Specs (Should have this at the top but I forgot and I'm on my iPhone so sorry)
Processor: i5 2500k @ 4.3ghz
Motherboard: MSI Z68A-GD65 (G3)
CPU cooler: noctua nd-d14
Graphics card: sapphire hd7970
Ram: G.Skill 1333mhz 2x4gb (black pcb)
PSU: Seasonic X-Series 760w
Storage: Crucial m4 128gb sata3
1Tb Samsung sata2
1tb caviar black sata 3
Chassis: NZXT Phantom USB3 edition
MOST IMPORTANT, a slight bit of coke was spilt into the fan at the top, I'm not sure if it has dropped on anything. (The system was running fine after the small spill, but problem started occurring the next day).
I'm fine with replacing whatever is spoilt, (the person who spilt the coke on my system is paying). But I need help with fixing it or finding out what is spoilt so I can repair/replace. Thanks!
1Tb Samsung sata2
