NZXT Switch 810 VS Cooler Master Cosmos II - Advice?
I am building a new system very soon and need plenty of room for water cooling, components, etc. After doing some research and reading reviews, I have decided it is between the new NZXT Switch 810 and Cooler Master Cosmos II cases. Therefore, I was hoping to get some feedback from actual owners of these cases to find out how you like them, pros, cons, etc.
Thanks for any input.
7 answers Last reply
More about nzxt switch cooler master cosmos advice
  1. I really like the cosmos II. Especially it's IO panel.
  2. These are cases from different prices. I mean really different. I will get the Cosmos II STRAIGHT AWAY :).
  3. switch 810 is like $150-$170 but cosmos ii is $300+,if budget is not a problem and you don't have any other choice then i would suggest cosmos ii.but there are a lot of cases of less price and will fit heavy watercooling setups.here's my suggestion-
    Coolermaster HAF X-
    Xigmatek Elysium-
    Corsair Obsidian 800D-
    i think that was enough to give you an idea.there are many other great cases(including mid towers)that can accommodate high end liquid cooling setup but it really depends on your taste and budget.
  4. Thanks for the reply, but I was only looking for owners that can give input on how they like their NZXT Switch 810 or Cooler Master Cosmos II as I have already chosen those two for what I want. Price not important, but either of those new ones I like best. They both have great reviews, but just looking for feedback from owners of either one to see about pros, cons, etc.
  5. it is not important to buy a case to know it's pros and cons.sometimes n00b owners can also give you wrong advice like"hey this thing is great because i own it" :lol:
    it is better to check out some good review sites for detailed information.
    While that can be true in some cases (pun intended), I find first hand experience to be the best. I did read several reviews as stated in first post, just wanted to see what owners had to say about them to decide between the two.
  7. my work is to give you advice,rest is in your hands! good luck anyway ;)
Power Supplies Cooler Master Switch Cosmos Components Product
