Closed
Problem with Installing HD 6850 - No Display
New Build. First Time Builder. Specs:
i5-2500K
GIGABYTE GA-Z68XP-UD3 Motherboard
G.SKILL Ripjaws X Series 8GB (2 x 4GB)
XIGMATEK Gaia SD1283 CPU cooler
SAPPHIRE 100315L Radeon HD 6850
Intel 320 Series 80 GB SDD (boot drive)
SAMSUNG Spinpoint F3 HD103SJ 1TB HD
Antec High Current Gamer Series 750W PS
Antec Nine Hundred Black Case
Windows 7 Home Premium
Initially I had post beep, but no display. I tried removing the 6850 and use the built-in graphics and was able to get video display after clearing CMOS. Now Windows is loaded and everything is up and running using the integrated graphics, but I can't get it to display with the 6850 card installed. I can hear windows loading, but no display. If I try to go back to the integrated video output, it doesn't work until I clear CMOS again.
The 6850 has power (at least the fan is running). GIGABYTE motherboard is suppose to be enabled with Virtu (allowing dynamic switching between the built-in graphics and the discrete graphics cards) but I went ahead and tried configuring bios to disable the internal graphics when a discrete graphics card was installed, but that didn't seem to make any difference.
Any suggestions?
GW
Ask the community
