Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > Power Supply and Buy Question
Forum Systems : New Build Power Supply and Buy Question
Here is my build: http://secure.newegg.com/WishList/ [...] r=13328589 with i5-2500k Processor.
Will the power supply in my build be enough for future CF/SLI if I EVER decide to go for it?
EDIT: My other question is, should I buy all of my items from newegg or amazon? I hear amazon is cheaper on some things but not as return-friendly. Any opinions?
Message edited by azeem40 on 02-06-2012 at 09:10:01 PM
Reply to azeem40
Are you talking about crossfiring another of the 7950's you have on that list. If so, the answer would be probably. The tests I've seen set the max draw of a pair of 7950's at 525ish watts. I don't have good numbers for the amp requirements on hand but I doubt that would be a concern with your selected psu. So the answer really comes down to how much power the rest of your system draws. Personally I'd give yourself another 100 or so watt buffer, to account for extra system load, as well as capacitor aging (your psu will deliver less watts the older it gets)
Reply to AMutedScream
I can do 100W more. I prefer AMD because of the lower power draw and comparable to NVIDIA for some cards. So for future AMD cards (about 5 yrs), what wattage would be best?
Also, I added a second question to my OP.
Reply to azeem40
Excellent psu
http://www.newegg.com/Product/Prod [...] 6817207011
5yrs? Nobody can answer that question unless they are psychic.
------------------------------ Core i3-2100/Asrock H61/8GB1333/XFX HD5850oc/WD Black 500/Antec 300/Antec EA380w bronze
Currently playing Deus Ex:HR a second time on Hardcore
Reply to geekapproved
OOOPS. My apologies, the draw numbers I quoted you were for 7970's, not 7950's! Max draw for 7950's is about 360 watts, which is embarrassingly LESS than my single GTX 480 draws! I use a 650 watt corsair with no problems, so your 750 antec should be just fine! You can still up the wattage if you want to futureproof yourself, but as it sits you're be just fine, assuming you don't have a ton of hard drives attached, or are planning on overclocking your system aggressively. Again my apologies for the bad info.
To answer your other question, unless you have significantly reduce the price of your build through amazon (and I mean significantly!), I'd go with newegg exclusively. A lot of times amazon only fulfills your order, with the actual product being shipped and processed from a different company (which may result in a ton of different return policies for different items). Newegg has just about the most bulletproof customer service and return policies out there. I've had nothing but good things to say about the process, and I know friends that have ordered items to have them arrive later that same day!
I plan to OC to 4.5 GHz. Are there any components that are worth buying from newegg? Does Amazon offer fast shipping like the 2-day shipping deal with newegg?
@ Singing: It is gonna be the G.Skill Sniper 2x 4GB RAM 1.25v for $50.
Reply to azeem40
There are 2063 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
$650 dollar budget 'gaming' rig. Can you help?
By geofelt, 1 hour ago:
To answer your question, an aftermarket cpu cooler is not necessary with a 2100. For $5...
Best offers
Top experts
