Strange dirt problem
Forum Digital Camera : Digital Camera General - Strange dirt problem
Archived from groups: rec.photo.digital (More info?)
I have a D70, about 2 weeks old.
At very high f-stops, there are 5 or 6 dirt specks on the images, which
become blurred at lower f-stops. (specks are always in the same place)
Replacing the lens made no difference, but there is no obvious dirt on
the sensor, and taking a shot with no lens gives no dirt. Also, if the
dirt were on the sensor, it would look the same no matter what the
f-stop, right?
So it's not the body, and it's not the lens...
Any ideas???
Sponsored Links
On 22 May 2005 13:50:05 -0700, google.20.jbloggs@xoxy.net
>f-stop, right?
Wrong. The dust particles cast a shadow on the sensor
(they're resting on the filter above the sensor itself). The
wider the aperture the softer/larger the shadows. The dust
will not be visible to the unaided eye, follow the
recommended cleaning procedure. This may help:
http://www.cleaningdigitalcameras.com/index.html
>Any ideas???
Regards
John Bean
Reply to Anonymous
> f-stop, right?
> Any ideas???
It happens. The dirt is actually on the sensor - or just above it, on
the filter. There are several ways to clean it, some scarier than
others. I have had good success by holding the camera face-down, doing
the mirror lock-up through the menu, and then giving it a few puffs with
a Giotto Rocket air bulb. A little puff or two of gentle air will
usually get the larger dust strands off the sensor.
You'll see them a lot more clearly at high f-stops than low f-stops
because the angle of the incoming light is less. It's the same reason
you can blur distance at low f-stops.
To make sure you've got it clean, put a lens on, set it to the smallest
aperture, point it at a white wall, and take a photo (flash will do).
Then look at the resulting all-white shot.
Reply to Anonymous
Tom's Hardware > Forum > Digital Camera > Digital Camera General > Strange dirt problem
There are 1384 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
