I saw a build pretty similar to this in another thread, mine is similar but slight changes here and there. I'm going to be gaming and web surfing, no overclocking of any kind. The final price is around 610$, which works for me. I have a copy of Windows 7 Ultimate 64 bit, so no need to include an OS. I have a monitor, mouse, and keyboard already. Planning to order this tonight, or tomorrow.
This will be my first time building a PC, I'm trying to get a family member to assemble it for me, but chances are I'll be doing that myself.
NZXT GAMMA Classic Series GAMA-001BK Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146061
I'm not very sure what to look for in a case, but this was recommended quite a few times on the forums. The case supports the motherboard, and this has good reviews, not sure what else I need to know about it.
Seagate Barracuda ST500DM002 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148767
HDD's are expensive... I don't think I'll need 1TB, if I run out of space I'll buy an external or something. Brand wise, this and Western Digital seem pretty similar. Someone suggested that since I can't afford a pure SSD, I should look for a hybrid, but I've yet to find any in the price range.
SAPPHIRE 100314-3L Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102948
I've read in alot of places that Radeon cards are doing slightly better then GeForce ones. Also I checked the stats for this card on the website and it has a really good score. I don't see the need for something stronger, but I also wouldn't like something weaker.
SeaSonic S12II 620 Bronze 620W ATX12V V2.3 / EPS 12V V2.91 80 PLUS BRONZE Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151096
It's about the same price as the 520w version, and it's certified. 620w also seems like something I can work with in the future, incase I need to add stronger components.
ASRock H61M/U3S3 LGA 1155 Intel H61 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157236
Good ratings and supports 6gb sata. I saw a few cheaper versions in the same series, but this seems nice with the potential for USB 3.0.
Team Elite 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory Model TED38192M1333HC9DC
http://www.newegg.com/Product/Product.aspx?Item=N82E16820313086
This and g-skill(I think) are about the same price. Review wise it seems solid, and it comes with something free! It was suggested to me that I get 1x 8GB, since the MOBO only supports 16 GB max with 2 slots. But it's a 20$ increase for the single stick, and I figure if I actually need to upgrade ram, by the time I do the prices will drop.
I probably should have put the CPU first....
Intel Core i3-2120 Sandy Bridge 3.3GHz LGA 1155 65W Dual-Core Desktop Processor Intel HD Graphics 2000 BX80623I32120 W/ DVD Burner
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.822341
Overall, I think this is the best choice price wise. I would go for the Amd Phenom II x4 960T BE, but I'm not going to overclock it, or unlock it. The i3-2120 is also on sale and about the same price as the i3-2100.
The main thing I've been checking over and over again, is that all the components work together. I know the MOBO is designed for the CPU, the PSU is enough for the GPU, and so on. As I said, this is my first time, and withering away in front of my PC for the past three days leaves me with only so much I can gained from it. Lastly, I plan on playing SC2, maybe SWTOR, and any other run of the mill f2p MMO. And probably Skyrim, the monitor I have sucks, but I'll work on that later, other I don't plan on doing anything more intensive.
Thank you in advance.
