Power supply for GTX 550 TI
  • Power Supplies
  • Gtx
  • Components
Last response: in Components
May 23, 2012 4:00:04 AM
I'm getting a GTX 550 TI and I'm not sure what wattage I need from the power supply. I currently have a 250 W I believe.
It's a stock Dell Inspiron 560 PC, Pentium (R) Dual-Core CPU - E5700 @3.00 - GHz - 3.00 GHz, 6 GB RAM.
The recommended power rating isn't listed on newegg for the card like some of the others.
Any help is appreciated.
More about : power supply gtx 550
a c 111 ) Power supply
May 23, 2012 4:44:47 AM
Corsair CX430V2 would be a good choice, however you know your pc is going to bottleneck the card!
m
l
a c 1218 ) Power supply
May 23, 2012 4:47:34 AM
For a system using a single GeForce GTX 550 Ti graphics card NVIDIA specifies a minimum of a 400 Watt or greater power supply that has a combined +12 Volt continuous current rating of 24 Amps or greater and that has at least one 6-pin PCI Express supplementary power connector.
m
l
May 23, 2012 5:16:08 AM
What card would you recommend then? I basically don't have a video card and i run diablo 3 now but its choppy. Don't need anything crazy, and important shorter on cash than expected.
Thanks ko! If i have 250 and need another 400 i may as well get get a 700w.
m
l
May 23, 2012 5:30:01 AM
Radeon 6670, you can essentially run the game at ultra settings!
A 430W Psu will run it easily!
m
l
