Solved
PSU Question! help
Was browsing on Newegg, building my first custom PC. Saw a pretty good PSU for an extremely low price. Is it worth picking it up. Also I really do like the red lighting it gives off. Has it at 119.99 standard. But with the rebate it will cost me 74.99 plus a 20 dollar promotional card. So 54.99 for a 119.99 PSU.
What do you guys think... Worth it or not?
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341041&nm_mc=OTC-pr1c3grabb3r&cm_mmc=OTC-pr1c3grabb3r-_-Power+Supplies-_-OCZ+Technology-_-17341041
5 answers Last reply Best Answer
More about question help
  1. I wouldn't trust my life with that power supply to be honest, so it doesn't get my vote.
  2. It's a decent power supply if you receive a non-defective unit.
    It's been known to burn out if overloaded (i.e. attempting to draw more than 980 Watts).
    Reputable review here: http://www.hardwaresecrets.com/article/OCZ-Fatal1ty-750-W-Power-Supply-Review/1019
  3. Best answer
    Quoting from ko888's posted link:
    "If you want to save even more, research carefully before buying it, because at this moment prices are varying quite a bit, from USD 105 to USD 129. If you are able to buy it for USD 105 you will be doing an outstanding deal, but even at USD 129 is not a bad buy at all."
    At $54.99 its a steal. Go for it.
  4. Best answer selected by liebejr.
  5. @liebejr, thanks for the best answer... but I would say the best answer is deserved more by ko888. The article was a good find & very relevant. Thanks ko888.
Power Supplies Components Product
