Sign-in / Sign-up
Ati 5670 3 monitor set up help
  • Graphics Cards
  • Monitors
  • Graphics
Last response: in Displays
December 8, 2011 5:42:58 AM
Hello,
I have this card http://www.newegg.com/Product/Product.aspx?Item=N82E168... and I'm trying to set up 3 monitors. Thing is, it's not for gaming. My wife wants to have a dual monitor set up and add an HDTV as the 3rd for streaming movies. Can it be done with this card? Can it be done at all with a DVI monitor, a DVI monitor added via display port adapter and an HDTV?
Also, the computer being used a Dell 620 and has an on board graphics processor with hdmi and vga ports.
More about : ati 5670 monitor set
a b U Graphics card
a b C Monitor
December 8, 2011 6:02:18 AM
I don't see why you shouldn't be able to connect your hdtv to your gpu. So long as your tv can accept the signal you should be okay, but one of the htpc guru's might be able to give a more definitive answer. Re the adapter, make sure that the DVI-display port adapter is active, NOT passive.
m
l
