Power Supply question and tips on anything you would change
Last response: in Systems
Hi
I currently plan on ordering
Thermaltake V9 BlacX Edition with Docking Station (NewEgg Exclusive) SECC / Mesh ATX Mid Tower Computer Case
ASUS Maximus IV Gene-Z/GEN3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
HIS IceQ Turbo H697QT2G2M Radeon HD 6970 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with ...
Thermaltake Black Widow W0319RU 850W ATX 12V v2.3, EPS 12V v2.91 CrossFire Certified 80 PLUS BRONZE Certified Modular Active ...
* Intel Core i7-2600 Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 2000 ...
G.SKILL Sniper Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL9D-8GBSR
Western Digital Caviar Black WD7502AAEX 750GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
LG Black Internal 12X Super Multi Blue with 3D Playback Blu-ray Disc Rewriter SATA WH12LS38 LightScribe Support - OEM
I plan taking advantage of the crossfire capabilities and using another one of these cards in the future and plan to overclock. Is the 850 psu enough for the future upgrade? Does anyone have any suggestions for changes on my current build? Any advice is appreciated thank you.
http://www.newegg.com/Product/ProductList.aspx?Submit=E... <---- get a better psu...any of those on that link will suffice, also check out the XFX 850w psu's.
Get rid of that motherboard if you plan on adding a second card in the future. That board is a mATX and has horrible spacing.
http://www.newegg.com/Product/Product.aspx?Item=N82E168... <---- something like this board here
And get a (K) cpu so you have the option to over clock. Either 2500K or 2600K
Ask the community
