Closed Solved
Psu problem need help
wat is the maximum limit of Cooler master extreme power 460w. that supports the graphic card in ati raedon Hd series...??
6 answers Last reply Best Answer
More about problem help
  1. Are you asking what graphics card you can use that CM power supply?
  2. You haven't told us what your other components are so hard to tell.
  3. Best answer
    I think it should be fine up to 6850, But I would rather put 6770/7770 there.
  4. Yes, what other components do you have on your computers? The computer can run up to any high level psu watts if it has to. You can use below site to see what psu wattage you need depending on the components on your system.
  5. Best answer selected by night3lf.
  6. This topic has been closed by Mousemonkey
Cooler Master Graphics Cards Power Components
