Solved
Problem withe resolution
Okay,
So, I've been experiencing something funky with the resolution in games and I can't quite place whether or not if the monitor is to blame or if it's the GPU.
My monitor (a 27" Samsung SyncMaster SA350) has a native resolution of 1920x1080.
http://www.samsung.com/us/computer/monitors/LS27A350HS/ZA
But when I play Prince of Persia (2008) (see pictures) the screen doesn't extend to a complete full screen. I've even gone to the registry to make sure that it is playing at 1920x1080 and the registry tells me that it is! :??:
Now, the same thing is happening to Crysis Warhead. It wasn't happening before. (see picture)
I have a MSI R6970 Lightning and it is connected to my monitor via HDMI Cable.
This doesn't happen to all games. So far it is only with Crysis Warhead, Prince of Persia (2008), and Prince of Persia Forgotten Sands.
I've checked the drivers for my GPU and they're all up to date.
Please help! I haven't been able to find the source of the problem much less a solution.
Thank you everyone!
5 answers Last reply Best Answer
More about problem withe resolution
  1. Go into CCC and make sure that under digital panel attributes you have GPU scaling enabled to full screen!
    It is already enabled to full screen.
  3. I have this problem too with Prince of Persia Forgotten Sands.
    I have GPU scaling enabled and 0% underscan.
    However on my computer i cannot deselect widescreen..but you can.
  4. Best answer
    I found a fix- make sure you have vertical sync enabled... cause it gets pretty crazy with lots of sync line problems... so all you have to do is run that program in the background when you play Prince of Persia Forgotten Sands.
    http://www.avsforum.com/avs-vb/showthread.php?p=19099835#post19099835
    http://www.oshinetworks.com/ATI_Underscan_Fix.2.2.zip
    i used version 2.2... and it worked.
    I did further reading and the game (forgotten sands) has problems when you use HDMI cable instead of DVI. you could switch to your DVI cable if you have one on the back of your monitor or use the fix program.
  5. Best answer selected by solinvictus01.
Graphics Cards Resolution Monitors Graphics
