Screen problem after installation of graphics driver
hi,
This is bakrudeen, i have a issue with my system is that after installation of graphics card, the start button has hidden and right side of the desktop screen has blank for half centimeter length( i thing the display has moved to left side)
Can anyone tell me what resolution of that above issue. :(
1 answer Last reply
More about screen problem installation graphics driver
  1. If you have Windows 7, right click on the desktop and hit Screen Resolution and try using the Detect and Identify buttons to see if they help. Also try changing the screen resolution selected below.
    If you are using Windows XP, then right click the desktop, hit settings, go to the farthest tab to the right, and you should be able to change settings in there.
Homebuilt Graphics Cards Graphics Systems
