P positive climb Distinguished Dec 4, 2011 30 0 18,530 Dec 9, 2011 #1 I have a Radeon HD 6950 and it has 2 connectors for power. Do I need to have both plugged in for the card to function? Thanks
Solution ilysaml Dec 9, 2011 yes you must plug the 2 x 6 PIN PCIE power connectors in order to get signal on screen and the card to function.
ilysaml Splendid Oct 30, 2010 4,854 0 23,460 Dec 9, 2011 Solution #3 yes you must plug the 2 x 6 PIN PCIE power connectors in order to get signal on screen and the card to function. Upvote 0 Downvote Solution
P positive climb Distinguished Dec 4, 2011 30 0 18,530 Dec 19, 2011 #4 Best answer selected by Positive Climb. Upvote 0 Downvote
