Okay, I assembled a list of parts to build my own computer and ended up doing that around 3 months back. Working flawlessly, the computer would do everything perfectly. Until now; during just any old skype session, my computer randomly froze and shut down. Upon booting it back up I was greeted with horizontal blue lines and the bios displaying odd text.. I came to the conclusion that my OS may have messed up but decided it shouldn't affect the Bios.. I researched it a bit and people with similar (but still different) problems said it was the gpu or bios. Any help would be very much appreciated, I don't have an extra graphics card to test. Pics below to show problems.
All that really should be needed are cpu gpu mobo and ram
But you really shouldn't be using the developer's version at least until beta comes out. Even then I don't recommend it because it could cause something like this.
I say you go wipe out that HDD and reinstall Windows 7.
I noticed after I took the ssd out, the bios still had the blue lines and the weird characters, I suppose I can try putting my laptop ssd with windows 7 in it and see if there is an significance. I know I should be using windows 7 but I am waiting to get my hdd before doing that.
Message edited by uhq on 02-08-2012 at 07:02:57 AM
