CPU is running a bit hot, can I still use it til I receive new cooler?
Last response: in CPUs
Related ressources
- How long til the i7-930 starts bottlenecking? - Forum
- CPU still too hot with new cpu cooler ... - Forum
- Celeron D 3 46 ghz running hot - Forum
- Intel 1155 or wait til next generation? - Forum
- HP Pavillion DV2500 Nightmares over heating, GPU and CPU running hot - Forum
Related ressources:
- ForumNew Core Duo system running a bit hot
- ForumInstalled new cpu cooler , runs a bit hot or is this normal?
- ForumE6600 still running too hot ?
- ForumI7 930 Stock cooler running very hot
- ForumHow hot should my i5-2500k run ?
- ForumI7 Running Too Hot Noctua NH-U12P Cooler
- ForumAMD Phenom II 970 X4 - Is it running a bit too hot ?
- ForumLarrabee not due til early 2010
- ForumGTX 460 Running very hot while gaming. Any tips?
- ForumSapphire HD7970 3GB GDDR5 OC running hot ?
- ForumThermaltake 850w PCI-E question
- Forum[Solved] Can I upgrade a laptop Intel HM67 chipset i3 dual core 35w TDP CPU?
- Forum[Solved] Are Cooler Master R4 SikleFlow's any good?
- ForumSudden CPU problems
- ForumNew CPU to replace my old AMD Athlon II X4 630
- More resources
