Bit of a problem... Help.
Well... I switched my desktop on as usual, then left it starting up whilst I went to the toilet for a minute. I come back only to be greeted with a black screen and the CD Drive led light flashing constantly. At first I thought the monitor was at fault so tested connections and plugged monitor into laptop, it worked fine on laptop, so then I tried replugging into the graphics card, still nothing so I plugged the monitor cable into the onboard graphics, still nothing... The computer is starting up and running but its not doing anything... The fans are working etc...
Please help :/
Maybe the heat has something to do with it but im not entirley sure as has 3 fans emitting and sucking air...
Thanks.
1 answer Last reply
More about problem help
  1. You will have to remove the discrete card for the onboard to work. Try resetting BIOS as well, pretty sure the fans have nothing to do with it.
Power Supplies Monitors Components
