Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > New system build need some opinions
Forum Systems : New Build New system build need some opinions
Hey this is my first system build and here are my specs:
CPU |AMD Phenom II X4 975 3.6GHz Quad-Core Processor $149.99
CPU Cooler |Cooler Master DK9-7E52A-0L-GP $9.99
Motherboard |Asus Crosshair V Formula ATX AM3+ Motherboard $219.99
Memory |G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory $59.50
Video Card |Sapphire Radeon HD 6870 1GB Video Card $149.99
Case |Raidmax Hurricane (Black) ATX Mid Tower Case $34.99
Power Supply |Diablotek 600W ATX12V Power Supply $28.99
Optical Drive |LG GH22NS90B DVD/CD Writer $15.99
Total |$669.43
I already have a 2TB external hard drive and a 23 inch monitor will i get performance worth the money im paying?
Thanks in advance!
Reply to cdiscoll2012
Alot of bad reviews about that cooler. If you are going to overclock you would be much better off with a Hyper 212+ or Hyper 212 Evo. You might as well stay with the stock cooler over the one you have picked out.
Power supply is absolute junk. The power supply is the most important part of your computer and not somewhere to save a buck. If you need to save money go with a cheaper motherboard or just get DDR3 1600 for $46. That is an expensive motherboard for AMD.
Here is a much better power supply that is fully modular for $69 after rebate.
http://www.newegg.com/Product/Prod [...] 6817703036
Here is a great nonmodular power supply for $55 after rebate.
http://www.newegg.com/Product/Prod [...] 6817207013
Message edited by anort3 on 02-09-2012 at 02:47:08 AM
------------------------------ i7 2600K @ 4.5/P67A UD4/Scythe Mugen 2 Rev B/OCZ Vertex 2 120GB/2xWD 640 Blacks/Antec 1200/Samsung 23in LED LCD/EVGA GTX 460/2x4GB GSkill Ripjaws X DDR3 1600 7-8-7-24/Windows 7 Ultimate x64/Corsair 750TX
Reply to anort3
Is this any better?
Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
OCZ 600W ATX12V / EPS12V Power Supply
i read a lot of good reviews of these but if I'm wrong though please tell me
The cooler is alot better but either of the 2 power supplies I listed are better than the OCZ. The OCZ is a decent unit though. You only need a good 500w power supply for what you have listed so either of the 2 I recommended give you plenty of headroom.
Reply to anort3
There are 2072 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
$650 dollar budget 'gaming' rig. Can you help?
By geofelt, 1 hour ago:
To answer your question, an aftermarket cpu cooler is not necessary with a 2100. For $5...
Best offers
Top experts
