First off let me say you guys and gals on the forums and Tom's Hardware in general are great. I have been coming to this sight for helpful information for years.
We, hubbie and I, do not do much as far as games anymore just play on pogo and watch movies.
With all of the newer movies, cameras, video recorders, and TV's coming out with 3D it looks as though it is going to become mainstream in the not so distant future. So I would like something that with minimal input could be adapted to that as the price becomes more affordible for the mainstrem market.
The motherboard in the computer I am replacing went out and I am going to replace it and give it to a friend that needs a computer for her kids.
What I may keep from the old computer:
Thermaltake shark case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133143
Thermaltake toughpower 850W power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153043
What I am looking at buying is on Newegg but I would not be opposed to other places if items could be found cheaper. I don't need this in a hurry as I have another pc and 2 laptops in the house that I can use. However these belong to the kids and between homework and games they keep them busy most of the time.
Rosewill Thor V2-white. Yes I like the white case better than the black one.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147158
Asus sabertooth X79 5 year warr.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131801
Intelcore i7 2600 No I do not over clock change voltage or any of that other stuff.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115071
Corsair vengence 8gb These were chosen specifically because they are 1.35v not 1.5v
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233244
EVGA GTX 560 Ti There is a 1gb and 2 gb version of this card not sure which to buy. I will probably get a second and sli in the near future. Just because I have never done it and would like to say I did. One item off the bucket ist so to speak.....
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130610
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130662
Corsair SSD 120
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233206
There you have it. Willing to take any input, suggestions, coments or concerns. Would like to get the price down a bit if I could but not truly a concern. Just hate to make the leap without a little advice from some folks with more knowledge than myself.
Corsair SSD 120
