Hey all,
So I just made my first computer and its running great except this whine/rattling noise that i hear. I first noticed it when playing games like warhammer and have tried to figure out whats causing it but without any luck.
The noise only comes when a game or gpu benchmark like furmark is running AND open. I can run furmark minimized without any problems but as soon as i bring it up the noise starts, and as soon as i minimize or close it it goes away. This is the same thing with the games.
I have opened up the case and stopped the fans on the gpu while the noise is happening and the noise continued so i don't think its the fans. I have also manually adjusted the fans on the gpu to every level from 40-100 and the noise doesn't show up. I am not sure if its the PSU or the GPU but it seems to be one or the other. I don't think its the CPU because when a run a cpu test like intel burn test the noise doesn't show up.
Any opinions on what is causing the noise and how I could fix it or figure out if its the PSU or GPU. Below is my relevant system info. If you need any future information to help me out please ask and thanks for any help/input.
Antec High Current Gamer Series HCG-750 750W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371049
Gigabyte GTX 560 ti
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125401
Asrock extreme3 gen3
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271&Tpk=asrock%20extreme3%20gen3
Gigabyte GTX 560 ti
