Should you use 6 pin pcie power connectors?
Last response: in Components
- Help, GTX 770, Do I use the 6 and 8-pin power connectors on my PSU labled PCI-E or do I use the adaptors? - Forum
- No 8-pin pci-e on my power supply... should I use 6 pin or 2 molex? - Forum
- gpu needs 6 pin power connector..... what should happend if I don't use a 6 pin p.connector - Forum
- How many 6 pin PCIe power connectors are needed for ATI R7 240 1GB DDR5? - Forum
- 6 pin pcie power connectors for Radeon HD 7750 ? - Forum
- Solved4 pin to 6 pin Pcie power connectors for HD7770 Forum
- SolvedCan I Convert Two 4pin Molex Connectors to 6pin PCIe to power AMD HD7870 Forum
- SolvedShould I use a 6 pin and 8 pin connectors on a single line for a EVGA GTX 760 or use one of the supplies adapters Forum
- GTX 760 Needs 1x6 pin and 1x8 pin. Can I use 2 6+2 PCI-E Pin connectors for this? Forum
- SolvedPowering GPU with 2 pci-e 6+2pin connectors Forum
- Should I use a 6 pin and 8 pin connectors on a single line for a EVGA GTX 760 or use one of the supplies adapters Forum
- SolvedShould I use a 6+2 pin PCI-E or 2x 6 pin PCI-E for an 8 pin graphics card. Forum
- SolvedHow do I know if I have a power supply using 6 and 8 pin connectors? Forum
- SolvedCan I use a 2x6-pin PCIe GPU with a 1x6-pin PCIe connector PSU Forum
- Solved2 x 6 pin PCIe power connector Forum
- Is it neccesary for me to use both 6pin power connectors for my gtx275 Forum
- Solvedcan i use the 6 pin connector on a modular psu to power a 6 pin lead to a gpu Forum
- I need to know if my graphics card will work with my motherboard considering my GC uses 2 6 Pin connectors for Power Forum
- Should I: Run two separate 6-pin PCI-E or a Y connector 6-pin to Dual 6-Pin Forum
- SolvedWhere to find PCI-e 6-pin connector TO power supply? Forum
- More resources
Read discussions in other Components categories
